KPI in variables
Hello
We were trying to put some calculated values in to variable and the idea was to make variable like static value and then recall the KPI from it.
But as You can see they are not recalculated. The outcome of this is just the body of the formula.
Is it possible to make variables value calculated from the KPI? Or maybe there is some way to calculate new value of variable inside the KPI? Like for example: var int test = 100? Or something like that.
#3
Hi Jany,
which Celonis version are you using?
Kerstin
#4
Hi
Process Mining 4.4
4.4.0-RELEASE_6683d3bd2f_20180528_1104
#7
Hi Jany,
you cannot write to static variables.
You would need to change the type of your variable to text/replacement.
Kerstin
