Is SNAP Data refreshing allowed?
Hi, all. Is there any way to refresh the data of a Snap Team without losing any customization made in the analysis workspace?
Thanks
Luis
Hi @luiscu
yes - the data is managed in Event Collection and can be managed independently of the Analyses in Process Analytics.
You can add new Data to your Data Model (e.g. by uploading a new csv File or by running the extraction for a google sheet), reload your Data Model, and then you should see the updated data in your Analyses.
David
Hi, David. Thanks for your answer.
If I’m using the SAP Account Payable quick start is the same?. I can see the file upload option in the event collection. Do I have to upload the same files (but updated) that I uploaded when I generated the analtics workspace for first time?
Thanks
Luis
Captura|690x346
Hi Luis,
what I would recommend if you used one of the processes in the Quickstart feature then is to reuse it with the new data and then simply assign this new data model to your old analysis. How to do it:
  1. Go to process analytics and your analysis
  2. Assign your new data model to it by clicking the button as shown below “Data Model”
I’ll try. Thanks!
Luis
