Invalid stoi argument
Hi community,
i faced following problem:
This is related to the following filter:
There variable is set as follows:
If i use the text of my variable directly in the filter it is working:
But then i loose the flexibility of the Dropdown button.
Has anyone faced a similar problem and has a solution for this?
Thanks
Regards Holger
Hello Holger,
can you try to make the ButtonDrilldown variable a “static value” (instead of “Text/Replacement”). Does that help?
If it doesnt fix the problem, can you please specify the Celonis version you are using (IBC, CPM4.5, …).
David
Hi David,
if i change it to static it gives me in direct preview and in the chart a NaN error (1):
When i open the formula editor (2) it shows me the expected result:
We are Using CMP 4.5 SP2.
Holger
