Index sheets - Front end
Hello All,
Anyone knows how to use and what is the benefits of using index sheets on front end analysis?
I tried using and seems it’s scanning open requests but not sure how is it working?
Thanks,
Kalpesh
Hi Kalpesh,
Thank you for your request. In general, you don’t need this functionality. The effect of this feature is the same as just opening each sheet in the sheet one-by-one. The Index Sheets does this in an automated manner, thereby executing all PQL queries inside all components. If the analysis contains complex queries for which the response takes more than one second, and if the query cache is activated and not full, the results for these queries will be cached, that means they will be available quicker when you open the respective sheet again.
Kind requests,
Max
