How to implement “Use case: O2C - On Time Delivery Prediction” on Premise
Dear Celonis Community,
We would like to implement Use case: O2C - On Time Delivery Prediction on our on-premise AS which is version 4.5
We checked the sample coding but it seems it’s prepared for cloud, Unfortunately
we couldn’t adapt sample use case for our data.
Many thanks in advance,
Vahide.
Hello @Vahide,
while not officially supported, the use case should also run with Celonis 4.5. Did you already get access to the ML suite package which contains the use case?
I will send you the link via Email.
Nicolas
Hello Celonis Team,
Thank you very much for your reply .
Yes we have everything that you listed via mail. We set up envirement.01_on_time_delivery_prediction.ipynb (165.0 KB)
We have the sample coding for the usecase(ones it was available on https://celonis.github.io/pycelonis/index.html but it’s removed ).
We wanted to adapt this sample code, but not able to succeed since sample code based on Cloud environment .
Our problem is lack of knowledge, we really with to implement ML algorithms to make process mining intelligient in our organization. Could you please support us ? Documentation or an hands on session ? we appreciated very much.
Vahide.
Hello @Vahide,
can you share the errormessage it gives you when running the sample code?
This will help us to figure out what’s going wrong.
Thank you
Nicolas
