How to easily set a negative filter
Hi, I was trying to easily filter something out, also in the snippets PQL reference I didn’t find this
is there an easy “Unlike” function, e.g. to filter out specific events (like NOT LIKE?)
#3
Hi Kristin,
I think for now you can not use NOT LIKE ‘%Wort%’. If you want to apply a component filter you can try
FILTER CASE WHEN "abc"."bcd" LIKE '%Wort%' THEN 0 ELSE 1 END = 1;
Does that work for you?
Max
#4
Hi Max,
unfortunately it is not working, we found out that for component filters where your chart or KPI is reflecting a calculated throughput time. We have tried the following: FILTER MATCH_ACTIVITIES(EXCLUDING_ALL[‘Document Blocked’] ) = 1;
all case when did not work whenever we were referring to eventlog.
#5
Hi Kristin,
Can you please let me know if I understand your question right? If I get you right, you have a component in which you calculate the Throughput Time of cases. You now only want to count those cases that don’t run through a specific activity. In your case this activity is ‘Document Blocked’. So in the below cases, you would only want to calculate the Throughput Time of case 1 and 3, correct?
Case1 , Activity1 , 12.1.2019
Case1 , Activity2 , 13.1.2019
Case2 , Activity1 , 12.1.2019
Case2 , Document Blocked , 15.1.2019
Case2 , Activity2 , 16.1.2019
Case3 , Activity2 , 13.1.2019
Case3 , Activity3 , 14.1.2019
Thanks and kind regards,
Max
#6
Hi Max,
exactly - we want to see the throughput time for all cases where this special activity is not included. it was easier to say "were activity like ‘…’ " - thats why I was asking for this “unlike” or “not like” …
#7
Hi Kristin,
You were already very close. In this example you can see how I filtered the cases that should not contain an activity. You can reach this with the component filter in multiple ways.
Example 1:
FILTER MATCH_ACTIVITIES("Eventlog"."Activities", EXCLUDING_ALL['Document Blocked']) = 1;
Example 2:
FILTER MATCH_ACTIVITIES("Eventlog"."Activities", NODE['Document Blocked']) = 0;
Max
#8
Hi Max - we have tried - it works … thx for the patience and solution!
