How to capture the Action Engine Signal in a CSV file from the Signal List
Is there any way to collect the list of signals from the signal list with the assignee details and all the action taken details if any, in a single csv file.
It will be necessary to find the details of the signals and to whom it is pending with, so that we will be easier for the business analyst to track the progress.
The CSV file must be from the Signal List which is yet be resolved.
It will be
Hi there,
a csv export from the signal list (my inbox) is not possible. However, you could analyze the usage in a datamodel. For that, you would need to extract the data via Python (ML Workbench) and push it into the data model. You can read more about it on https://celonis.cloud/help/display/CIBC/Data+Export
Viana
