Healthcare Related Connectors
Are there any process connectors, data model and analysis in healthcare domain or pharmacy related ?
Hello @rajdeepak,
Yes Celonis definitely has many Use Cases in the Pharma and Life Sciences Sectors.
  1. The Process Connector will solely depend on the ERP or IT System the Healthcare/Pharma Company is using.
  2. The Data Model can be OTC or PTP or AP or AR, based on the Process Model.
There is a very good documentation on the Used Cases and KPI’s that can be used in Pharma at the Partner Portal’s Library (Product Knowledge/Industries).
You can refer that, it will help you.
Warm Regards,
Jayanta
