Flagging data or adjusting data in the frontend visible for multiple users
Hello Community,
We are developing a new algorithm to help users detecting duplicates.
As an inspiration we toke the blog:
We have noticed that the algorithm detects false positives. In the algorithm, this might happen because we do fuzzy matching and searching. Now the users like to flag these false positives in the sheet. Moreover, they want the flags they made to be visible for other users using the sheet. How would you implement such a flagging system?
One idea we had was creating an additional column in the table that can be adjusted by users in the frontend. In this way, the adjustments could be visible for all the users. Does somebody have any idea whether this is possible?
Happy to hear your thoughts :slight_smile:
Paul
