Filter while importing data into Celonis
Hi Celonis Team,
Is there a way that while we load data into Celonis from one HANA table/view we can apply some filters to import only a limited dataset?
For example, I have two years of data in cases table but want to load only the last 6 months data into Celonis.
Regards,
Sachin
Hi Sachin,
in order to answer your question in more detail, it would be very helpful when you could tell us the Celonis Version you’re using.
Viana
Hi Viana,
We are using CPM 4.4.
Regards
Sachin
Hi Sachin,
since you’re using 4.4, you have connected your data model to a specific schema (most likely called CELONIS) where your celonis activity and case table as well as additional master data are stored. Within that schema your case table is actually a view, the best practice here is that you add the filter within that view.
Viana
Hi Viana,
Thank you for your response. This should do.
Regards,
Sachin
