Extraction filter on BSEG
I’m extracting data from BSEG table with a filter BSCHL IN (‘31’), but when i check the data after extraction i can see data related to posting key ‘40’ & ‘50’ . What might be the reason behind this, is something i’m missing in the extraction filter. Below is the query i’m using.
SELECT DISTINCT BSCHL FROM BSEG --> the result is 50, 31, 40
Appreciate the help
Thanks
Hi Chanti,
have you performed a full load after adding the filter?
Viana
