"Extracter" for SAP ECC ?
I’ve learned that there is an “extractor” for SAP tables provided by Celonis.
Does this “extractor” support SAP S4HANA only ?
Or does this support SAP ECC also ?
Thank you for your help in advance.
Hiroomi Nakazawa
#2
Hello!
Just to make sure: which product are you talking about? The Intelligent Business Cloud?
Our Extractors in the IBC are capable of extracting from both, SAP ECC as well as S4HANA. Furthermore our pre-configured connectors from the App Store are capable of providing templates of standard and common custom configurations for both systems with the corresponding transformations and Data Models.
So yes, both works well, though: details according to the customisations you made in your system should be further discussed, but are generally never a show-stopper.
Michael
#3
Dear Michael,
Thank you for your answer.
I’d like to know for both IBC and on premise solution.
I’m glad to know that IBC version support ECC too !
Hiroomi Nakazawa
#4
Dear Hiroomi Nakazawa,
Happy I could help. This is also true for the “Leave your data in place” / Hybrid solution (on-premises) that we offer.
Michael
#5
Dear Michael,
I’m glad to know that both IBC version and on premise version support ECC.
Hiroomi Nakazawa
