Exporting Tables
Is there an option to export extracted tables on the back-end as CSV files?
Hormoz
Dear Hormoz,
You can see below post to solve your issue.
Dear Kaztakata,
Thanks for the response! However, I’m not sure if it helps with the issues I’m looking into right now. Specifically, I would like to know if Celonis has a built in capability to allow users to export extracted tables as CSV files? Say for example, I have used Celonis to extract a certain table from SAP and would like to export the entire table as a CSV file.
Hormoz
Dear @hormoz.izadi,
If you would like to find solution in Process Analytics, it is just create OLAP table in Analysis sheet to extract all table columns, then use download of component.
https://help.celonis.cloud/help/display/CIBC/Analysis+Interaction
Or if you would like to find it in Event Collection, my previous link is helpful.
Kazuhiko
Thank you Kaztakata! This helps.
Regards,
Hormoz
