Exporting a scroll-able component (chart) to PNG does not show the entire chart
As the title says, exporting a chart that scrolls to PNG only shows the area that is captured within the current window. Is there a way to have the exported PNG show the entire chart?
CPM_OLAP_Table_20200902_152303|690x141
Hi Alex,
This is not directly possible, but as a workaround you could either
a) export the data to Excel and create a graph there, or
b) change the component settings to display all columns and export it afterwards.
Best regards!
