Export to excel OLAP with saved formula
I am trying to export to excel data which contains a saved formula in some columns. I have downloaded Celonis APP for AP: Payment behaviour. I have noticed that when I change from saved formula KPI to formula directly, then there is no issue to export to excel. If I refer to saved formula in column value, then I get error Failed: Code 500.
Is there a possiblity to export data to excel which includes saved formulas in column values?
Thank you in advance for clarification
Hey Ksitarsk,
Unfortunately we are not able to replicate this error and would thus recommend you to contact our Service Desk directly so our according Specialist can search for the mistake on your system.
Benedict
