Edit process model
frontend
I have a question regarding function edit process model. What is the purpose of this function.
Will there be in future possibility to design process flow and then compare it to the actual process ?
Thank you
Best regards
Adam Štefanča
#2
Hella Adam,
Welcome to the community!
Could you please provide which product (Celonis Process Mining 4 or Intelligent Business Cloud) you are referring to and also where this function you talk about lives?
Our Conformance Checker seems to do exactly what you are looking for. I can tell you more if that is what you are looking for.
Michael
#3
Hi Michael,
thanks for answer. I am using Process mining tool. I know the conformance check functionality. I am curious what is the View process model used for ? Its only a visualisation tool for us, or we can create our process map there, and Celonis will then compare it to the actual processes from activity table ?
Best regards
Adam
