Drop down/filter by attribute of a specific activity
Hi everyone,
I need to create a drop down that will allow me to filter cases shown in the analysis by the value of a specific attribute of a specific activity.
In particular: I need to filter cases where activity ‘remove billing block’ was performed either by user type A or B.
Process O2C in SAP, if that is important.
Thank you very much in advance
Regards
Masha
Hi Masha,
my approach would be the following:
CASE WHEN “ACTIVITY_TABLE”.“ACTIVITY_EN” IN (‘remove billing block’)
THEN CASE WHEN “ACTIVITY_TABLE”.“USER_TYPE” =‘A’ THEN ‘USER TYPE A’
WHEN “ACTIVITY_TABLE”.“USER_TYPE” =‘B’ THEN ‘USER TYPE B’
ELSE ‘USER TYPE NOT KNOWN’
This PQL-Formula selects the cases where the activity ‘remove billing block’ is part of the process. After selecting these cases, the PQL-Formula then checks the user type and adds a dropdown option accordingly.
Data Science Team
Thanks a lot!
I actually already solved this one like this:
CASE WHEN “_CEL_O2C_ACTIVITIES”.“ACTIVITY_EN” LIKE ‘remove billing block’
THEN “_CEL_O2C_ACTIVITIES”.“USER_TYPE”
ELSE ‘not relevant’ END
But thanks for your response anyway, it helped me to verify that I found the right solution. I’m just learning to use celonis:)
Regards,
Masha
