Data row extraction limit in data job
Is there a way to change data row extraction limit in data jobs in Celonis Cloud.
Only 100 first line are displayed in output.
Thank you in advance
Hi Mounia,
In fact, there is no extraction limit. The reason that you only see 100 lines in the output of the transformation workbench is that this view is limited to 100 rows. When you load the data in a Data Model, you will see that you can have a lot more than 100 rows in a table.
Regards,
Leonid
Thank you for the reply.
I want to extract directly from the view for testing purpose as i don’t have Access to the database directly. Is there any way to increase the number of displayed rows in views?
Hi Mounia,
Would it be possible for you to add the table to a Data Model and load it? In Process Analytics you would then be able to view the whole table.
Leonid
