Data model master data reuse
Hi All,
We have a data model-1 with activity table and connected with all master data tables.
Can we reuse the master data of data model-1 in data model-2 directly in celonis?
Is there any option like maintain/load all master data tables into celonis and use in various data models rather than loading the same master data for each data model ?
Thank you.
Hi Gopi,
If you add the same tables to multiple Data Models they will in the end use the same data from the database so you are not duplicating any data.
What is exactly your concern with having the same tables in multiple Data Models?
Leonid
Hi Leonid,
Thank you for your update.
Our concern is about the memory on the celonis DB gradually increasing for each data model. This is fine until we have enough memory. Currently we are working on the ways to reduce or control the memory usage.
I would like to know the process, how to use the master data of data model-1 in data model-2 directly in celonis? Can you explain the steps if this is possible!
Thank you.
Regards
Gopi
