CPM 4.5 - error when clearing variable
It is quite useful to clear a variable (set to empty) using a button.
It was possible in CPM 4.4 but not anymore with CPM 4.5.
An error message is shown with the text “Button action is not defined. Needs to be defined by analysts”.
Bruno
Hey Bruno,
You could define a button which writes the standard content to a variable rather than clear it or is this not a possibility? Also you could write the value zero to it if it is a Integer / Float.
Bene
Hi Bene,
When setting a variable, it is useful to clear another one, specially if they are related.
Unfortunately it is a string and not an integer/float.
This was working properly in CPM 4.4. It’s sad to lose features when changing Celonis versions.
Bruno
