Connection with IFS (ERP and Field Service Management)
Has anyone connected to an IFS ERP and/or Field Service Management software before? If so, it would be great to hear about your experience (which scenarios, whether it was easy etc).
Thanks,
Maarten
Hi Maarten,
We worked with an one-time extraction (CSV) from IFS and implemented the Order-to-Cash-Process.
  • In terms of logic, IFS is very simple in comparison to e.g. SAP or Oracle
  • First technical implementation could be done with almost the same effort than a “classic” implementation of SAP O2C with process connector from AppStore
  • There are tables for ORDER, ORDER_LINE and, accordingly, the history tables for each order and item
  • There are also tables for the header and line items for the invoice
If I can be of assistance, please do not hesitate to contact me.
Kay
Thanks, Kay. Not at this time, but I will definitely keep you in mind!
Cheers,
Maarten
