Conformance way of working
Hi all!
I’m trying to understand how the conformance app works. I wanna basically deal with an ideal process flow I built and see how it conforms to the data inputs. The issue in here is that I can’t figure out few things:
1_I designed a model myself without introducing a certain syntax (xor or whatever), is that a problem for the conformance app? I didn’t get an error for it.
2_Why i obtain different conformance levels i filter time range from the benchmark app with respect to directly filtering on the conformance app?
3_Can I establish a conformance by simply linking the conformance to a variable in which i put all the process flow I’m ideally expecting?
Thank you
