Conformance checking based on Models4Insight process models
We’re using Models4Insight to model our business processes. We would like to import these models in Celonis to use them as reference for the Celonis conformance check. Is there anyone with experience on this?
Dear Rob,
thanks for your message.
You are able to import and use process models in the Celonis conformance checker from any modeling tools as long as it is in BPMN standard and the activities naming match the activities of discovered cases in Celonis.
you can export BPMN from your tool and import them in the conformance checker. for naming convention, you can directly adjust activities after you import them to Celonis. When you click on each activity, you can see a dropdown that includes existing activities of your process model.
best,
Product team
Dear product team,
Thanks a lot for your answer
Br Rob Buijtendijk
Process Excellence Support Lead
