Conformance Checker Gateway parallel symbel
I see that the “mine process” for the conformance checker can create the Parallel symbol. If I create the process from scratch, I do not see how to add such a parallel symbol.
Any help is appreciated :).
Hi Paul,
you need to create the normal exclusive gateway first. Then you can change the type of the gateway with the “change type” button ( image ):
Cheers
David
