Category with top spend.
Hello Team,
I need to add the category with the highest spend into a text Component and also mention the spend amount.
Can you help me how can i do it?
Regards,
Sachin
Hello Sachin,
in order to solve this, you could add a variable (static value) MAX_SPEND with the following content:
MAX("Categories"."Spend")
Then, add the following query to a text component:
MAX(CASE WHEN "Categories"."Spend" = <%= MAX_SPEND %>
THEN 'The category ' || "Categories"."Name" || ' had the highest spend (' || "Categories"."Spend" || ')'
ELSE NULL END)
Unfortunately, this only works if the category with the highest spend is not filtered out by sheet/component or selection filters.
If you are on the IBC, you could also wait until the next release, where we release a new PQL function that allows you to index values based on a certain sorting. This can then be used to write a nice query that also works with all kinds of applied Filters.
David
Thanks David,
I will explore this option.
Regards,
Sachin
Hi David,
Categories in my case are repeated in the table.
Hence I need to first sum-up the spend under all the categories and pick the category name and spend with highest spend.
Note – I also sheet filters + component filters applied.
Regards,
Sachin
in order to first sum up values, you can use a PU_SUM, something like:
PU_SUM("Categories", "OtherTable"."Spend")
But I dont know a solution for when you have filters applied. You’ll need to wait for the next release, then the new functionality will help.
David
