CASE WHEN for multiple conditions
Hi team,
i am trying to write a CASE WHEN statement for a process explorer to show only the activities that satisfy a dropdown filter based on multiple selections.
Sample dataset:
(Case ID, Activity, Source,…)
Case1, Activity 1, Screen1,…
Case1, Activity 2, Screen1,…
Case1, Activity 3, Screen2,…
Case2, Activity 2, Screen1,…
Case2, Activity 4, Screen1,…
Case1, Activity 5, Screen3
I would like to be able to filter in a custom process explorer the activities only from a particular screen (e.g. filter dropdown: Screen1 and Screen 3–> only Activities 1, 2, 4 and 5 are shown on the process explorer).
My current query doesn’t allow me to select multiple conditions, and doesn’t work with the ‘IN’ function as well:
CASE WHEN “BOOKS_USER_05JUN”.“SOURCE” LIKE <%=Source_Process%> THEN “BOOKS_USER_05JUN”.“ACTIVITY” ELSE NULL END
Dominic
Hi Domenic,
what should work is a Component Filter in the process explorer with a defined variable:
FILTER "BOOKS_USER_05JUN"."SOURCE" IN (<%=yourvariable%>);
Then you can let a button dropdown choose the Screen values and write it to the above defined variable.
This should lead to only the activities for the respective Source type.
Celonis Data Science Team
