Calculate throughput for SOURCE/TARGET
Dear Colleagues,
a quick question. We can easily calculate either:
DAYS_BETWEEN(PU_FIRST(Activity1), PU_LAST(Activity2))
or use
CALC_THROUGHPUT(FIRST_OCCURRENCE[Activity1] TO LAST_OCCURRENCE[Activity2]
but is there any easy way to calculate the throughput but for various cobmination of activities?
I used SOURCE(Activity) and TARGET(Activity) which gives me a table with combinations of activities, but I cannot add any KPI which would calculate the throughput for this combination.
So what I would like to achieve:
Source(activity) Target(actvity) Average Throughput time
A1 A2 3
A1 A3 2
A2 A4 5
and so on…
Hi Ksitarsk,
you can use
AVG ( DAYS_BETWEEN(
SOURCE("activities"."timestamp"), TARGET("activities"."timestamp")
to calculate the avg throughput time in days for each edge between activities.
Cheers
David
Thank you for the solution. It works as expected. I have one more question: is it possible to calculate the throuput inside the case from each acvity to the same target? In the example I am showing 1 case, where combination of source - target? So I would like to have a throuput from different preceding activities to the same target activity.
Something similar is available in case explorer, where all the timings are calculated to selected activity.
If I understand you correctly then you want the Average Throughput Time from all activities until say ‘Invoice posted’?
You can do that by setting a component filter:
FILTER TARGET(“activities”.“activity name”) = ‘Invoice posted’;
It’s just an idea but if you want to show the average time until different activities you could create a button drop down where the viewer can select an activity (load entries “activities”.“activity name”), which is written to a variable and used in the filter instead.
Best wishes,
Calandra
