Button dropdown does not display all values when I "Load Entries"
frontend
For some reason, the Button dropdown component does not display all values for a particular field. I am comparing it to an OLAP table containing the exact same field. When I copy certain values from the OLAP table and search in the Button dropdown, it does not find them. I should add that none of these components have filters on them.
Is there a hidden limit in terms of values for the Button dropdown?
Thanks,
Alex.
#3
Hello Alex,
May I ask whether you are talking about the Intelligent Business Cloud or Celonis Process Mining 4 (and which Version if CPM4)?
What kind of values are you trying to display?
Michael
#4
Hi Michael,
We are using Celonis Process Mining 4.2.0.
I am trying to display material numbers (“EKPO”.“MATNR”).
