Bookmarks disappear
I have a question regarding to bookmarks. In our Celonis environment there is productive folder with a productive cockpit, which is used for daily work. Besides there is a test folder in which a test cockpit is further developed.
If I want to replace the cockpit from the Productive folder with the test Cockpit, the bookmarks created by the users in the productive cockpit disappear.
Is there any way that the bookmarks can be preserved?
Thank you very much for your help.
Jonas
#3
Hi Jonas,
which version do you currently use (Celonis 4.4, SAP Process Mining by Celonis 4.3.1, or IBC?)
I revised the steps for the upcoming release Celonis 4.5 and on the IBC. On both products if you move an analysis to an different folder (IBC: workspace), then it works and the bookmarks are kept.
For the upcoming release Celonis 4.5, SAP Process Mining by Celonis 4.5 and currently live on IBC we revisited the bookmarks and increased the usability of organising bookmarks:
Michael
#4
thanks for your reply.
I currently use SAP Process Mining by Celonis.
Then I’m looking forward to the release.
Jonas
