Automation rate
Hi all,
we’re currently only considering user types to define which activities have been done automatically (batch user) and which have been processed manual (all other user types):
100.0*AVG(CASE WHEN “_CEL_P2P_ACTIVITIES”.“USER_TYPE” IN (<%=auto_user_type%>)
THEN 1.0 ELSE 0.0 END)
However, for our MRP runs which shall be also considered automated there is always a manual user in SAP. We can identify MRP runs by the doc type (EP) in combination with the PR creation indicator (B).
Any suggestions how we can adjust above formula to also consider EP in combination with B as automated?
Thanks :slight_smile:
Oli
Could you extend your CASE WHEN statement to include a second check whether the username is in a list of usernames?
For example (I don’t know the exact SAP table/column names):
THEN 1.0
WHEN "_CEL_P2P_ACTIVITIES"."USERNAME" IN (<%=auto_user_name%> THEN 1.0
ELSE 0.0 END)
Bonus suggestion: you don’t need the 100.0* if you set the display format to % (with decimals).
Hope this helps!
Thanks for the fast feedback! However, the extension shall not be based on user names but on a combinantion of PR Creation Indicator (B) and on PO Document Type (EP). I’ve tried to update the formula as follows but always receive the error message that tables _CEL_P2P_ACTIVITIES and EBAN do not have a common parent in the schema:
100.0*AVG(
CASE
– WHEN “_CEL_P2P_ACTIVITIES”.“ACTIVITY_EN” NOT IN (<%=ActivitiesUsedInAutomationRate%>) THEN NULL
WHEN “_CEL_P2P_ACTIVITIES”.“ACTIVITY_EN” IN (<%= ActivitiesUsedInAutomationRate %>) AND “_CEL_P2P_ACTIVITIES”.“USER_TYPE” IN (<%=auto_user_type%>)
THEN 1.0
WHEN “EKKO”.“BSART” = ‘EP’ AND “EBAN”.“ESTKZ” = ‘B’
THEN 1.0
ELSE 0.0
Any idea/suggestion how to solve?
Thanks, Oli
Hey Oli,
I think this problem is connected to the other question I just answered.
To solve your problem, it probably should help to put the EBAN part of your statement into a Pull Function, most likely PU_COUNT should be used so here it goes:
100.0*AVG(
CASE
THEN 1.0
WHEN “EKKO”.“BSART” = ‘EP’ AND PU_COUNT(“EKPO”, “EBAN”.“ESTKZ”, “EBAN”.“ESTKZ” = ‘B’) > 0
THEN 1.0
ELSE 0.0
Benedict Lang
Great, thanks so much! That solves the problem indeed :slight_smile:
