Analysis migration from On premise to IBC
Hello, there is a manual to migrate analysises from an on premise version to IBC version?, one year ago we did 6 customized analysis in an on premise version, now, more or less in one month we need to migrate to IBC environment.
is it possible to use the same analysis we build previously?
is it possible to install the current analisys on IBC environment?
Thank you
Hi @francisco.gaitan!
You can use Python with pycelonis for this job.
See here how to copy an Analysis from one instance to another:
https://celonis.github.io/pycelonis/notebooks/99_Use_Case_Copy_Analysis.html
Note that your Python instance needs to have access to Celonis 4 and the IBC.
Hope this helps
Nicolas
Thank you, I will check the option.
