Adress specific values in a table
Hello everyone,
I would like to know if it is possible to adress a specific value in a table (not the first, last, max, or anything else).
For example:
I have the table VBEP and the field ETENR. For an order position I can have different delivery schedule line numbers. I’m only interested in the first schedule line with a confirmed quantity >0.
Has someone an idea how I can adress this problem? Check whether the quantity is >0, if not, go to the next schedule line with a quantity > 0
Friedemann
#5
Dear Friedemann,
Thanks for your question. PU functions allow you to set a filter. In your case we suggest you use:
PU_FIRST(“VBAP”, “VBEP”.“ETENR”, “VBEP”.“BMENG”>0)
This will give you the first Delivery Schedule Line Number with Confirmed Quantity greater than 0 for each Order Position.
Viana
