Activity counts in PivotTable not working correctly
I have a PivotTable with activity name (horizontal) and resource (vertical) as dimensions.
I have case count as KPI, this works as expected. Activity count however returns ‘1’ in each cell which is non-zero. Using COUNT_TABLE() works correctly however.
Any logical reason why this happens?
Joos
#3
Hi Joos,
could you please specify what kind of process you are looking at and which dimension you mean by resource (table name and column)?
Henry
#4
The same here. You need to use a count_table(“Activity_Table”) and i also wondering why. Does it show the number of distinct activities when i use count(“activity_table”.“activity”)?
#7
Hi Henry,
Sorry for not noticing your reply before.
We are using a custom dataset (so not a SAP mapping). Resource in this case was employee: I was looking to see if certain activities where performed by only a subset of employees, and vice versa.
#8
Thanks for your question.
This issue will be solved in Celonis 4.5 where you can do a count based on column values.
In previous versions you have to do the calculation via COUNT_TABLE, just like you already described.
We are sorry for the inconvenience.
Viana
#9
Thanks for your clarification @v.kalversberg, another reason to upgrade :slight_smile:
