Action Engine removal of duplicates on 1 column
I created a action engine skill and it’s going very well. Since I am using approver name as a connection for the process automation to send email. I don’t want that the approver will be bombarded with multiple email if he/she has many invoices that needs action. Is there a way to remove or filter approver with the same name only regardless of the other columns he/she has?
Thank you.
Example:
Hei @rcat71192,
thank you for your question.
You can set up your action engine skill using the approver as the signal ID. You have to set up the signal ID right after creating the skill (look at the attached file). The Signal will then be grouped by the approver.
Does this answer your question?
Data Science team
